400 Hydraulics
Bill N
02-15-2004 19:56:50
Big 400 just got a loader mounted on it. Functions well but does not lift too heavy of a load. I put in new hyd oil, and am wondering if there is any way to get more hyd pressure? thanks.
Klyde
02-16-2004 09:48:49
 Re: 400 Hydraulics in reply to Bill N, 02-15-2004 19:56:50
High flow low pressure. Go with larger diameter cylinders.
Pat T
02-16-2004 03:28:33
Best bet would be to plumb a pressure gauge in line, max pump pressure is 1200psi. If pressure is low, could be plugged filter, worn pump. leaking bypass valve/valve assembly. Guess the biggest question is whether 1200psi will do the job you want to do with the loader?
Pat
Wolverine
02-16-2004 04:44:01
 Re: Re: 400 Hydraulics in reply to Pat T, 02-16-2004 03:28:33
I had a loader on my 400 super diesel and it always seemed weak to me. so I took it off, painted the tractor and show it instead.:)
