Case LA serial number
Matt
02-15-2004 15:26:10
I am wondering if someone can tell me what year a LA is by the number on the engine block
caseman-d
02-15-2004 16:03:09
 Re: Case LA serial number in reply to Matt, 02-15-2004 15:26:10
The LA should have the serial # located on the engine block flange by the air cleaner. Once you have that number we can tell you what year it is.
caseman-d
Matt
02-15-2004 19:28:07
 Re: Re: Case LA serial number in reply to caseman-d, 02-15-2004 16:03:09
The number is 4862A.How do you know by that number?
Tom Railsback
02-15-2004 20:02:54
 Re: Re: Re: Case LA serial number in reply to Matt, 02-15-2004 19:28:07
YOu don't; that's just the part number for the
block.
Look on the left rear flange and there should be a number stamped on it. That's the serial number.
Matt
02-16-2004 16:36:54
 Re: Re: Re: Re: Case LA serial number in reply to Tom Railsback, 02-15-2004 20:02:54
The number on the rear flange has been rubbed off somehow.That's why I was wondering if it could known by just the block number.
Tom Railsback
02-16-2004 19:58:07
 Re: Re: Re: Re: Re: Case LA serial number in reply to Matt, 02-16-2004 16:36:54
Crawl ubder the tractor and look on either side of where the drawbar pivots. There should be a casting date which is probably as close as you are going to get if the serial number is completely gone. I wonder if you might have a tractor that had the block replaced with a new one direct from the factory. That could explain why there is no serial number.
Jim P
02-17-2004 06:38:16
 Re: Re: Re: Re: Re: Re: Case LA serial number in reply to Tom Railsback, 02-16-2004 19:58:07
In the World WarII years and a few years after the war dealers and some reg. people dealt in black market tractors. They ground off the ser. no on the block and threw away the plate so they could sell the tractors without a no. to trace the sale. I bought a 47 LA at auction in 56 and it was that way. I took the paint off where the ser. no was supposed to be and poured on sulfuric acid and it brought out the no.
Tom Railsback
02-17-2004 19:34:00
 Re: Re: Re: Re: Re: Re: Re: Case LA serial number in reply to Jim P, 02-17-2004 06:38:16
It seems like I learn something here almost every day. I guess I have too simplistic an outlook on life.
