Case 1210 transmision noise
Don Pease
02-15-2004 06:29:59
I have a Case/DB 1210 4x4. The transmision makes a ticking/light knock in 1st gear, all ranges. It is the same going streight, right or left. The noise appears to be under the seat area, but is hard to find exactly. It has been doing this for years. Any suggestions? Thanks, Don
Elmer
02-15-2004 07:26:42
 Re: Case 1210 transmision noise in reply to Don Pease, 02-15-2004 06:29:59
Either your reverse idler or first reverse gear has a tooth missing. Remove you high low shifter and look to the rear of the transmission. The reverse idler is on the top shaft and the first reverse gear is on the bottom shaft.
