530 backhoe
cp
02-14-2004 18:11:29
I have a 530 backhoe. It runs great, except the valve bank leaks. Does anyone know where to get used parts?
Roger (Mi)
02-17-2004 05:59:45
 Re: 530 backhoe in reply to cp, 02-14-2004 18:11:29
The control valves for the backhoe operation have replacable sealing rings. After throughly cleaning the top of the valve bank, remove the control rod pins. There are two screws holding the control valve cap on the bottom of the bank. Once the screws are removed, the control valve/s can be pulled out the bottom. Use a stiff wire or ice pick to remove the top sealing ring from the valve body. The bottom sealing ring will come out with the control valve. It's best to remove the the control valve spools one at a time, and don't mix them up. Install the new sealing rings and reassemble. Good luck.
George S. in the real NY
02-15-2004 13:01:28
Email me with "CASE PARTS' and anything else in the subject line and what part of the country or world you are in and maybe I can put you on to parts. Also, exactly what do you mean by valve bank, not familiar with the term.
