1070 powershift
jwr
02-14-2004 01:01:22
My 1070 has developed a squeeling noise when I shift the powershift. Eveything works fine. It also squeels when I take off from a standstill in 4th. It makes the noise downshifting also. I have changed the filters and my pump is very new. The noise is not coming from the powershift valve, it sounds like it is coming from down by the filters maybe pto/flow divider valve? I need to know what may be causing this. It has been very cold here and I considered ice in the oil somewhere. Thank you
Roger (Mi)
02-17-2004 06:18:25
 Re: 1070 powershift in reply to jwr, 02-14-2004 01:01:22
There are adjustments on the top of the transmission cover for the various clutch packs. Those adjustments are there to provide a smooth transitions for the engagement of one clutch pack to another. If they are out of adjustment, they will either allow two clutch packs to be engaged at the same time (motor pulls down and squealing)or there will be a laps or hesitation in the power shift. If that's your problem, you're advised to get a manual before messing with those adjustments.
Allan C
02-14-2004 12:53:07
Is it a hydraulic squeal or could it be the torque limiter slipping.
jwr
02-14-2004 15:21:15
 Re: Re: 1070 powershift in reply to Allan C, 02-14-2004 12:53:07
It sounds to me like a hydraulic noise it does not sound like it is coming from the torque limiter. I split this tractor in january and the torque limiter was fine then. It does not feel like anything is slipping.
Allan C
02-15-2004 13:23:58
 Re: Re: Re: 1070 powershift in reply to jwr, 02-14-2004 15:21:15
Hydraulic noise could be anything - like you say, ice or just heavy oil causing a valve to do funny things. The valve body is on top of the transmission just under your feet. Could it be coming from there?
jwr
02-15-2004 13:56:45
 Re: Re: Re: Re: 1070 powershift in reply to Allan C, 02-15-2004 13:23:58
The noise is not coming from the powershift valve right under my feet it soundslike it is coming from the area where the filters are
turbo
02-14-2004 11:38:28
My guess is the torque limiter, which is a spring loaded clutch type plate on the flywheel, is slipping . Sometimes the bolts that hold the belleville washer back out or it is just failing. This failure always shows the most in 4th gear.
