Case 530, New to me. Need some info about it
Phillip
02-13-2004 19:15:29
I recently found a Case 530 with a loader and backhoe. It is gas, has good tires, tin, new brakes, all new hoses for the backhoe, needs a hose for the bucket. He claims it runs good. About what are they worth? How many horse is it? How much does it weigh? Thank you for your help.
George S. in the real NY
02-15-2004 13:17:19
 Re: Case 530, New to me. Need some info about it in reply to Phillip , 02-13-2004 19:15:29
I agree with Roger's comment. New hoses are worth a few bucks. Two things to check before you buy: One is the pins and bushings where the parts pivot. Pin wear can be delt with, if the bushings are oval or worse, worn thru to the machine parts or are busted out, then be careful, get the advice of someone who has experience with replacing/repairing such items. The other is to be sure that there are no cracks around the mounting holes for the rear wheels. A third thing to check would be for noises coming from the hydro pump when a control is activated. There should be a little but lots of growling could be $$$. I have a 530 tlb and really like it for puttering around on a farm. The previous owner kept the pins greased so most were in good shape, except a few on the backhoe. Case had new bushings for one , and I used plain cold rolled steel for pins. Check the archives here under 530 and see what else there is.
Roger (Mi)
02-14-2004 05:05:48
A 530 loader/backhoe will have 43 horsepower. It will weigh approx. 6 tons. If it runs and operates well, it's worth $5000 plus.
L Schulte
02-16-2004 16:24:22
 Re: Re: Case 530, New to me. Need some info about in reply to Roger (Mi), 02-14-2004 05:05:48
I think Phillip ment 6000 LB in stead of 6 ton. I have a 580 ck and it and trialer only weigh around 8000 LBS.
The 580 shpuld be a good loader and backhoe.
I'am looking for a 3 pt hitch for mind. I have the quick hook backhoe.
