Oil pressure gauge on SC?
Josh
02-13-2004 14:11:40
I am fixing up my old '41 SC. A new set of gauges is in my plans, but i notice that the reproduction gauges include an oil pressure gauge that reads from 0-60 lbs. Mine is unreadable, but the pressure gauge on my VAO only goes to 30 i think. The VAO runs around 12 psi. Does an SC have more oil pressure? Is the 60 psi gauge the correct one? Thanks again for all the advice.
Josh
Roger (Mi)
02-14-2004 05:15:57
 Re: Oil pressure gauge on SC? in reply to Josh, 02-13-2004 14:11:40
Oil pressure on Case "gasoline" engines are only in the 20 pound range. Gauges are still available from a dealer or after-market that only go up to 40 pounds.
dctom
02-13-2004 16:18:09
JOSH;; YOU CAN GET THE RIGHT ONES OUT OF ANTIQUE GAGES IN DELEWARE BUT THEY COST TWICE AS MUCH
Josh
02-14-2004 06:10:17
 Re: Re: Oil pressure gauge on SC? in reply to dctom, 02-13-2004 16:18:09
Are the imported after market gauges any good? Will they fade quickly, or scratch? Thanks for the advice.
Josh
John Saeli
02-14-2004 10:47:19
 Re: Re: Re: Oil pressure gauge on SC? in reply to Josh, 02-14-2004 06:10:17
Hey Josh: I have a NOS CASE Temp guage with a real glass face for $60.00 if that helps.
John Saeli
02-14-2004 10:24:47
Hey Josh: Those imported guages actually use a glass face that won't scratch. The USA guages use a plastic face. I've had no complaints of fading. Don L. & I both stand behind the guages we sell.
