Duel Remote Hyd. Leak on 770 agri-king
Mark in OK
02-13-2004 01:57:50
I have a 1973 case agri-king 770 gasolne tractor that i bought in January. Knowing it had a weak engine i got a good buy on it. I completely rebuilt the motor and it runs great. My problem is it has a major hyd. leak around the seal in the hyd. duel remote control box. The seal where the two control levers enter the control box. Is there any good advise out there on removal and repair. My repair manual shows more than just the seal in the bottom, it looks like there are several O rings inside but gives no details. Also will the gas tank,fenders, ect need to come off for access. Thank you, Mark
Thad
02-13-2004 03:59:55
 Re: Duel Remote Hyd. Leak on 770 agri-king in reply to Mark in OK, 02-13-2004 01:57:50
You will have to loosen the rear mounts so you can lift the platform up. Then you can just barely get to the top two bolts. I have never removed the fuel tank to do one or fenders. The valve has the two orings and the seal at the bottom is more of a dust seal than a oil seal. Hope this helps. Thad
