sc generator same as others?
josh
02-12-2004 09:31:09
I am working on my '41 sc and the generator on it is from a chrysler car. Will the generator from the VA series fit, or does it need to be off an SC? Is it an autolite or a delco remy? Thanks for the info.
Josh
GS Austex
02-12-2004 12:08:13
 Re: sc generator same as others? in reply to josh, 02-12-2004 09:31:09
Josh-
I'm also trying to restore the original electrics on my SC (late model).
Maybe some one else can add to this but I'm getting the impression that the 6v neg. ground autolite systems that Racine built cases (SCs,DCs,ect.) used at this time are fairly uncommon as tractors go and are not the easiest to get parts for. One reason why someone would switch to 12v or even pos. ground.
Josh
02-12-2004 14:32:30
 Re: Re: sc generator same as others? in reply to GS Austex, 02-12-2004 12:08:13
I didn't even realize it was supposed to be negative ground. I think that v a l u - b i l t has rebuilt generators, and also the regulators for them, but they are pricey. I guess then an SC or DC generator will work, but VAC will not becuase it is positive ground?
GS Austex
02-12-2004 15:56:48
 Re: Re: Re: sc generator same as others? in reply to Josh, 02-12-2004 14:32:30
I think thats right.
The regulator is the key. I ordered the valuebilt reg., it appears to be just a cutout relay with no field terminal. I called their number for the expert who wasn't much help but maybe I can 'makedo' with it. For more info see my earlier post that Klyde responded to. If you find out anything more let us know.
Good luck
