Rocker arm buttons
Les...fortunate
02-11-2004 12:03:09
Just got a set of them from the dealer. All this time trying to figure out how to cob something together and come to find out the parts are still available. Duuurrrr.
This is for the SC.
Les...ARRRRGGGHHH!
02-11-2004 16:30:59
 Re: Rocker arm buttons in reply to Les...fortunate, 02-11-2004 12:03:09
Those "buttons" ain't what I needed after all. It's the piece that's on the other end of each rocker, the part that actually pushes on the valve. Can anyone help?
Old Eb
02-12-2004 08:26:36
 Re: Re: Rocker arm buttons in reply to Les...ARRRRGGGHHH!, 02-11-2004 16:30:59
Nothing like working backwards. Not to worry...I do it all the time. :)
Klyde
02-11-2004 19:46:09
How worn are they? If their not wore too bad grind them flat, we do it all the time.
Les...fortunate
02-12-2004 11:29:32
 Re: Re: Re: Rocker arm buttons in reply to Klyde , 02-11-2004 19:46:09
I don't get it. If they're already worn out, why would you file/grind them off further?
george md
02-12-2004 12:02:37
 Re: Re: Re: Re: Rocker arm buttons in reply to Les...fortunate, 02-12-2004 11:29:32
Les, Are you talking about the part of the rocker
arm that makes contact with the valve stem ? If
so , and they have a very small amount wear , regrind them . If they are worn badly I build them up with a fusible powder spray torch and then grind back to size and shape.
george
Les...fortunate
02-12-2004 19:18:33
 Re: Re: Re: Re: Re: Rocker arm buttons in reply to george md, 02-12-2004 12:02:37
Thanks, George. They are very badly worn. We'll have to look into that.
george md
02-13-2004 11:58:12
 Re: Re: Re: Re: Re: Re: Rocker arm buttons in reply to Les...fortunate, 02-12-2004 19:18:33
Les ,
The powder I use is about 60 rockwell C scale , it won't wear out again for many many hours running (years). If you can't find someone up there to do it ,send them down , it doesn't take long to
do a set .
george
