Cracked block
Walter
02-09-2004 19:57:48
After freeing my stuck SC and boring it out I discovered a small hairline crack in the block between the number 1 and 2 cylinders. Its about 1/2 inch long and neither of the liners are cracked. It extends from the edge of one liner to the edge of the other one. Is this the end of the line for this block or can I do something to salvage it?
Josh
02-10-2004 14:13:24
 Re: Cracked block in reply to Walter , 02-09-2004 19:57:48
Don't worry. Mine is the same way and works fine.
Art
02-10-2004 06:38:48
Thats still a good block....Almost all cases will have small cracks between the cylinders Thats just in the water jacket....
DKase
02-10-2004 06:36:34
If the crack is between the sleeves, and only on the top,(not in the crankcase) put it back togather. It will be fine. The head gasket seals up to the top of the sleeves, not the block.
Walter
02-10-2004 12:38:10
 Re: Re: Cracked block in reply to DKase, 02-10-2004 06:36:34
Its only on the top, but I wasn't sure if the head gasket would seal it ... there is only a 1/8 inch between it and the cylinder. Just the width of the liner lip. Thanks!
