What is the going rate for a Case S tractor?
Nicholaus Sowde
02-09-2004 14:46:07
What is the going rate for a Case S tractor? Just something close to what they bring. Thanks
richard
02-12-2004 07:17:36
 Re: What is the going rate for a Case S tractor? in reply to Nicholaus Sowder, 02-09-2004 14:46:07
Bought my '41 SC for $400. Had to replace the radiator($100), rebuild the waterpump($80)cleaned the mag, rebuilt the carb($25) and placed freebee tires on it. Found it sitting behind a warehouse in downtown Waukegan IL. Man said it didn't run. Should have seen his face when I drove it on the trailer under its own power. pics in under single fornt wheel SC
caseman-d
02-09-2004 17:57:40
All depends, nonrunning 300.00-1000.00, running 800.00-2000.00. Lot varies to your area and condition of the tractor.
caseman-d
Gene Dotson
02-09-2004 16:04:48
Bought my 1944 Case "S" about 3 years ago from the orchard region of western Michigan. Tractor ran, had decent sheet matal and good wheels, but junk tires all around. Had to replace the manifold, oil pan, fenders and grille. Paid $700.00 for it. It is now restored and would not consider less than $3000.00 for it. My favorite parade tractor. Not many in Ohio... Gene
Glenn FitzGerald
02-09-2004 17:57:41
 Re: Re: What is the going rate for a Case S tracto in reply to Gene Dotson, 02-09-2004 16:04:48
I suppose I should know this but what exactly is a Case S? I know the SC stands for S Cultivator... Is S any one of the tractors with that engine? Or is it like the D compared to the DC? Thanks, Glenn F.
Duane
02-09-2004 18:15:47
 Re: Re: Re: What is the going rate for a Case S tr in reply to Glenn FitzGerald, 02-09-2004 17:57:41
third party image
Yes, Glen..... the S is to the SC like the D is to the DC. A standard version of the SC.
Nich. The Case S is a heck of a lot cheaper than a JD BR. I like the S's myself. Bought one off ebay with loader for $500. It runs but with very low compression. One of these days, I'll do a valve and ring job.
I'll try to post a pic.
Mike Schotte
02-09-2004 18:48:33
 Re: Re: Re: Re: What is the going rate for a Case in reply to Duane, 02-09-2004 18:15:47
Hi Duane,
I think I remember that tractor on Ebay. Did it come with an extra set of spoked front wheels? (not mounted)
-Schotte
(also in TX)
Duane
02-10-2004 04:42:27
 Re: Re: Re: Re: Re: What is the going rate for a C in reply to Mike Schotte, 02-09-2004 18:48:33
Hey, Mike
Yes, thats the one. I would like to find a newer S to put this loader on and take this '42 back to original with those spoked wheels. Them wheels don't look heavey enough to support the loader. It has cut-off rears.
Where are you in TX. Are you a member of TEDTEA.
Maybe I'll see you at the GAS UP in Temple on April 3rd.
Mike Schotte
02-10-2004 05:53:57
 Re: Re: Re: Re: Re: Re: What is the going rate for in reply to Duane, 02-10-2004 04:42:27
Hi Duane,
Yeah- I was trying to convince Dr. Cy Kosis to buy that tractor and sell me the spoked front wheels.
I contacted the seller about buying them, too- but he wouldn't split them up.
Please give me a buzz if you change your mind about putting them on...
I'm located in the DFW area. Not a member of TEDTEA, but I've been to the Temple show a couple of times.
I'll be at the Glenrose show this weekend if you are going to be there.
-Schotte
Duane
02-09-2004 18:20:54
AHH, rachet computer won't post a pic..... .
Link
dctom
02-10-2004 06:18:32
 Re: Re: Re: Re: Re: What is the going rate for a C in reply to Duane, 02-09-2004 18:20:54
DUANE; THAT WOULDNT BE AN SC-4 FRONT END WOULD IT? KINDA LOOKS LIKE IT IN THE PIC
caseman-d
02-09-2004 17:59:40
S is standard and SC is rowcrop.
caseman-d
Dave_D
02-10-2004 09:19:47
 Re: Re: Re: Re: What is the going rate for a Case in reply to caseman-d, 02-09-2004 17:59:40
Cut little thing.
