Help Identify 530 or 630 ?????
Paul
06-27-1999 19:32:13
I had a guy give me a old case tactor. It's a 4 cyl diesel looks like a 530??? the only picture i have seen that close, but without a serial number I dont have a clue. It has numbers cast in the block CWC J76 and A37205, trans case has cast numbers g1352 and g1700. It has a tag on the back of the radiator 4020c61. It also has cast spoke wheels and tire size of 13.6/12-36 with a adj wide front end. The tach has marking for pto speed for 530, 530c, 630, 630c. thanks
Jerrie A. Lott
06-27-1999 19:48:43
 Re: Help Identify 530 or 630 ????? in reply to Paul, 06-27-1999 19:32:13
Paul I'm sure if they made a 530 diesel but at any rate there should be a tin plate attached somewhere near the dash, I know on my 1030 it is below the dash on the fire wall. Alos there should be a tag attached near the govoner housing o the engine that gives the cubic inches of the engine. I would think that a 639 diesel would be around 245-250 cubic inches since a 730 diesel is 277 cubic inches if it would happen to be a 530 it would be another 25-35 cubic inches smaller than that. Jerrie
0.Shaun in Wisconsin
06-28-1999 11:03:25
 Re: Re: Help Identify 530 or 630 ????? in reply to Jerrie A. Lott, 06-27-1999 19:48:43
If this truly does have 36inch adjustable rear tires that would make it a 630. This has a 188cid. The 188 came on the 430, 530, and 630 tractors. Hopefully this information will help you out. Email me for any further questions.
Sincerely, Shaun
Jerrie Lott
06-28-1999 13:51:39
 Re: Re: Re: Help Identify 530 or 630 ????? in reply to 0.Shaun in Wisconsin, 06-28-1999 11:03:25
I agree with Shuan about the 36" tires, but I'm not sure about the engine cubic inches, since it is a diesel, in all of the other CASE tractors of that era the diesel engine was about 25 cubic inches bigger than the gas engine in the same tractor. The 630 might be different I don't know. JJerrie
Shaun Finnessy
06-29-1999 07:03:51
 Re: Re: Re: Re: Help Identify 530 or 630 ????? in reply to Jerrie Lott, 06-28-1999 13:51:39
Jerry
If you get the hot line Blue Book this will get you most of the info that you need in these matters.
But a better source would be the OLD ABE NEWS
it is full of Info and is a ton of good reading.
the summer of "97" issue goes through the (Small) "30" series tractors.And you can purchase past issues.
Well any way here it is the 430 gas 148 cid deisel 188 cid
530 gas 159 cid deisel 188
630 gas 188 cid deisel 188
Paul
06-30-1999 19:59:40
 Re: Re: Re: Re: Re: Help Identify 530 or 630 ????? in reply to Shaun Finnessy, 06-29-1999 07:03:51
Thanks for the info. My problem is all the ID tags have been removed. I would like to know if any parts with casting number are different. I am trying to buy manuals. The lift had a problem and the guy took it apart.
Steve
07-01-1999 20:24:13
 Re: Re: Re: Re: Re: Re: Help Identify 530 or 630 ????? in reply to Paul , 06-30-1999 19:59:40
I never have seen a 530 with cast spoke wheels and have never seen a 630 without them...maybe other have.. just my 2cents worth
