SC problems
wolverine
02-07-2004 20:43:55
The last 2 times I have takin my sc out for snow scraping it has run good about 10 minutes and then just quits. I crank it choked and not untill battery dies, then I put the jumpers on it, crank it some more and it just starts up, sputters a little then runs great from then on. I think it must be in carb somewhere. when it does it ,I leak gas from the short rubber hose that connects carb to air cleaner. any thoughts?
jerry
02-08-2004 12:39:42
 Re: SC problems in reply to wolverine, 02-07-2004 20:43:55
Wolverine, What it sounds like is igntion problem. You say it runs then gets warm and quiets. If this tractor has a coil or mag. check and see if you have spark and check and see if you have voltage to the coil. Could be as simple as a pionts and condensor or coil. JUst my thoughts.
Jerry
todd hamilton
02-08-2004 12:38:05
I find my SC to be pretty touchy in real cold weather at the ten minute mark - it always starts but after about five minutes it gets sluggish and I have to adjust the choke a little for proper rich/lean. I notice frost forming on the intake manifold above the carb when this happens. I think the temp difference between the fuel and the manifold causes this. If you can nurse it until it warms all the way up (no frost on manifold) it should lean out and run o.k.
Brent
02-08-2004 07:47:22
Last two posts are right on. It's also possible there's some debris up in the petcock, and it clears up every once in while.
In cold weather, ANY condensation, or just plain water, will freeze and cause ice crystals to block the flow of fuel.
I've had problems with both debris in the petcock, and a stuck float (both stuck open and stuck closed).
I've also had problems with the ignition switch getting dirty, and shutting the tractor off for no reason at all. For the dirty ignition switch, watch the ammeter to figure this out - it'll go to 0 if the switch cuts off.
Hope this helps.
keith
02-08-2004 05:19:04
You may have some water in your gas that is freezing try and put some fuel deicer in the tank.
Dave
02-07-2004 22:39:26
wolverine,
When the fuel leaks from the air cleaner hose that usually means that the bowl is over fillng, so maybe your needle and seat had a small piece of debris in it and then cleared itself, after you cranked it awhile.
Check the fuel system to make sure no rust or particulate is floatin' around in there.
Good luck
Dave
