Next Step in VAC Project
John L.
02-07-2004 15:45:31
Well, things may be looking up. My father called me a bit ago and said he pulled off that glass fuel bowl on the VAC and it was full of "stuff" again. Keeping in mind that this is the VAC that we've had to turn the gas off on between uses for the past 20 years, I figured the "stuff" was gasket parts, which it was. Anyone know where to get a direct replacement for that gasket, or does anyone have a part number? Also, didn't I read someplace that there was supposed to be a screen in that bowl to prevent stuff like this from getting into the carb? Of course now I'm wondering if any of this stuff got back into the carb and is going to be blocking anything up.
As usual, thanks in advance!
C. Amick
02-08-2004 17:00:10
 Re: Next Step in VAC Project in reply to John L., 02-07-2004 15:45:31
I use the plastic in-line fuel filters to keep that stuff from getting into the carburetor. If you don't want to pull the tank off and clean it, the next best thing to do is to unscrew the sediment bowl and stick a short piece of copper tubing in the threaded end, so that the debris on the bottom of the tank is not pulled into the sediment bowl.
Paul Janke
02-08-2004 07:00:27
I have successfully used and O ring instead of a gasket on sediment bowls.
Joe (Wa)
02-07-2004 16:38:17
The screen is above the gasket. The purpose is to keep the crap and water droplets in the bowl as opposed to carrying over into the fuel line.
Gaskets and screens are available from Case and many farm supply stores. Get a neopreme gasket, cork tends to harden and flake off into the bowl.
Gasket p/n A11208, same as 360679R1.
Screen p/n A11211, also 49923D.
Joe
John L.
02-07-2004 17:07:48
 Re: Re: Next Step in VAC Project in reply to Joe (Wa), 02-07-2004 16:38:17
Thanks Joe! I've sent the part numbers on to my father so he can order them. Hopefully this will do the trick. The idea now is that maybe it's getting too much air and throwing the mix off so much that it can't fire. Hope this does it - I'm running out of ideas!
