David Brown 885 Hydraulics
Simon
06-27-1999 17:00:09
Having trouble getting the correct adjustment for the TCU valve on my DB 885 diesel. Have used a manual but it was incorrect. Would appreciate any information on DB 885 hydraulics.
Elmer
06-27-1999 18:52:04
 Re: David Brown 885 Hydraulics in reply to Simon, 06-27-1999 17:00:09
Are you talking about the main spool in the control valve. If so, their is a tool for setting the adjustment. Only dealers had them.
Simon
06-29-1999 15:56:57
 Re: Re: David Brown 885 Hydraulics in reply to Elmer, 06-27-1999 18:52:04
It is the TCU valve in the control valve. Original problem was the linkage slowly lowering when carrying load. Once lowered, could not raise the linkage. Have removed the control valve and reset the spool and TCU valves. Put the control valve back in and the linkage would raise but not lower. Thinking the TCU valve was blocking the flow we removed the control valve again and re-adjusted the TCU valve. Put the control valve back in and this time the linkage is lowered and won't raise at all. Does the spool valve need re-adjusting? The flow of oil is not being cut-off to make the linkage raise. Getting confused. Have replaced all O-rings and seals as well.
Elmer
06-30-1999 04:37:10
 Re: Re: Re: David Brown 885 Hydraulics in reply to Simon, 06-29-1999 15:56:57
I'll have to get my nose in a book. Their are so many symptoms that can happen to that hitch. Usually when the hitch won't raise and remotes have flow and pressure the bypass and hold valves are stuck. When the hitch is raised and won't lower the latching valve is stuck. When the latching valve is stuck links will lower with weight. Make sure rod with spring to quadrant lever is not bent and binding. TCU (traction control unit) was mainly used for tillage. Lever in middle was lower position. Lever in full back was raise position. Lever in full forward was raise with 500 psi to lift cylinder, enough to not raise plow out of ground, but enough to transfer weight to rear wheels. System worked well, but i never saw one farmer use it. They always used the draft position. When changing the selector lever, the quadrant lever had to be in the full back against the spring. Or you will break the selector fork. Alot of these 3 point hitch problems are not easy to tell someone how to cure over the phone or email.
