SC Clutch - Help
Rob in Virginia
02-07-2004 15:08:02
Hey guys, I am removing the engine in my 1950 SC. When I pull the engine forward on the splitting pins the clutch hand lever moves forward too, then the engine won't move forward anymore. I removed the clutch hand hole covers and see the fork assembly and throwout bearing are moving with the engine. There must be something I failed to do. What do I need to do to get the engine to come on out? Thanks.
HOOSIER
02-07-2004 19:51:55
 Re: SC Clutch - Help in reply to Rob in Virginia, 02-07-2004 15:08:02
You can also remove the bolts that hold the Pressure plate to the flywheel. Good Luck
Fredct
02-07-2004 16:53:48
Rob, you're testing my memory but, I think that you need to disconnect the clutch lever arm (my name) from the shaft that goes to the throw-out forks. This allows the forks to disconnect from the bearing. This also makes reassembly a little tricky. Good Luck! Fredct
Rob in Virginia
02-07-2004 17:34:24
 Re: Re: SC Clutch - Help in reply to Fredct, 02-07-2004 16:53:48
Thanks, I'll try that tommorrow.
