SC carb interchangability?
Josh
02-07-2004 13:13:58
I have a 1941 case sc with zenith carburetor. The bottom casting is cracked. Will the bottom casting from other zeniths fit, or do i need one specifically for an SC? Thanks
Josh
C. Amick
02-08-2004 17:07:31
 Re: SC carb interchangability? in reply to Josh, 02-07-2004 13:13:58
I think that other bottom castings will work. I would try to find one that has the same top mounting bolt hole spacing (2-3/8" center to center)just to be sure.
fixerupper
02-07-2004 15:57:24
I knew of a guy who was looking for a carb for his S and he said the inlet was bigger than the carb on an SC. I don't know what year the S was. Did the standard tread S series have a bigger air cleaner?
Mike Schotte
02-07-2004 14:09:45
Zenith had lots of similar carburetors- usually the only difference was jet size, which side the choke control was on, or whether or not the intake was flange mount,etc.
For an SC- it's what they called a type 61 or 161 carb series.
You should be able to find a donor casting from another carb.
-S.
Josh
02-07-2004 15:33:06
 Re: Re: SC carb interchangability? in reply to Mike Schotte, 02-07-2004 14:09:45
I have seen your other posts and have another question. My SC has the early style air cleaner with the outlet that is above the carburetor. The bowl on the air cleaner is rusted out. Will a bowl from any SC air cleaner fit on it? Thanks a lot!
Josh
Mike Schotte
02-07-2004 15:47:15
 Re: Re: Re: SC carb interchangability? in reply to Josh, 02-07-2004 15:33:06
Josh,
I think so- but I've never seen them both side by side. You've also got to remember- yesterday was the FIRST TIME that I ever had a GOOD oil cup in my hands! (thank you, FSB)
I saved photos of a '41SC air cleaner off of Ebay last week (sold for $80!)... it looks the same, except for the high air outlet and the looped cup springs.
I'm going to a commercial kitchen supply store on Monday to check out their stainless steel mixing cups.
I'll be sure an post if I get lucky and find a source for something we can all use as a replacement...
-S.
Brent
02-07-2004 15:23:24
I think there are two differnet sizes of carburetors used on the SCs, both Zenith models. One is physically larger than the other. The carburetor in my SC is the larger of the two. I would assume that the bowls would not be interchangeable between the two, but that is just an assumption on my part.
I can get the model # off it tomorrow if you want.
Mike Schotte
02-07-2004 15:32:44
 Re: Re: Re: SC carb interchangability? in reply to Brent, 02-07-2004 15:23:24
n/t
