Case 900B
Bowlegs
02-07-2004 11:23:46
Found a 59 900B lots of parts left on it if someone needs them. I will check and see what the guy wants for them if you email me. Engine is there may be stuck (diesel) starter, Rear tires 16.9 X 34 90 % weather checked. I have no interest in the tractor just letting everyone know about the parts. It is gonna be scraped.
mallard
02-08-2004 06:42:41
 Re: Case 900B in reply to Bowlegs, 02-07-2004 11:23:46
Good Morning
If the 900 is a 1958 I'd be interested in the injector pump and dash. Would you check and see if there is a belt pully on it, I might be interested that also.
mallard
caseman-d
02-08-2004 14:19:46
 Re: Re: Case 900B in reply to mallard, 02-08-2004 06:42:41
The 58 900B had the single plunger injector pump up to serial number 8141036 before switching to the multiplunger fuel pump after serial number 8141036. The 59 had the multiplunger which would be a plus for the 58 as it had higher rpm settings.
caseman-d
Bowlegs
02-08-2004 13:24:45
No belt pully but the dash is there but is a 59 model by sn
Gene Dotson
02-07-2004 16:25:22
Where is the tractor located and does it have a good seat?.. Gene
Wayne Whitehead
06-06-2004 09:29:26
 Re: Re: Case 900B in reply to Gene Dotson, 02-07-2004 16:25:22
HI I'm trying to fine a source for Hydraulic Pump Bushings for my 900B Case. I live just outside Las Vegas. Any help or suggestions would be appreciated. Thanks Wayne
