830 update and question
Brent
02-06-2004 20:16:51
We mike'd the crankshaft today - looks good. We also pulled a piston out to mike it and the sleeve.
The piston has 3 compression rings, or that's what I'm assuming. There is something in what I would call the piston oil ring groove, but it looks like only half of it is there. There really isn't much of anything in the groove to actually do any sealing. In fact, the groove in the piston is almost totally absent of anything - it's just void of anything.
It certainly doesn't look anything at all like the piston ring setup on our 1370. Those pistons have what I'm familiar with - the 2 compression rings along with a oil ring that looks like it's 2 rings in one, with a spring going through it.
No particles fell out as the piston was being removed - I checked for that...what's going on here?
all pistons are the same
02-07-2004 11:36:35
 Re: 830 update and question in reply to Brent, 02-06-2004 20:16:51
We pulled out all four pistons. All of them have the same setup for the oil ring...or should I say "lack of setup".
I also stopped by the Case IH dealer and looked at the pistons rings that would come from them. The dealer piston rings are exactly like I thought, similar to the oil rings in the 1370 and even the VA series.
In all four of the pistons from this engine, there is some sort of segmented ring in the oil ring groove, but it is completely at the bottom of the groove. Most of the oil ring groove space is comepletly empty. I have no idea how this could prevent oil from entering the combustion chamber.
Here is a stupid question: what is at the bottom of the oil ring groove, with the oil ring removed? Is it possible that someone never put the oil rings in during a rebuild?
Anyone have any ideas?
