801B
Adam
02-06-2004 19:37:30
What is an 801B with a spun bearing worth? Is it worth fixing if I can do the work myself? I haven't seen the tractor but they are asking $600. Don't know about shape of tires or tin.
ted
02-06-2004 19:57:13
 Re: 801B in reply to Adam, 02-06-2004 19:37:30
All those questions are very important, the sheetmetal alone could be worth more than the price they are asking, especially if the fenders are good. A decent set will bring $400. If the stuff is rustend, bent up, junk, then you better figure the weight times the scrap iron price. Another question. Does it have Case-O-Matic?? If so does it work? If not you might as well forget it unless you have a good parts machine.
Adam
02-06-2004 20:09:18
 Re: Re: 801B in reply to ted, 02-06-2004 19:57:13
I don't know anything about a Case-o-matic. When I go to look at the tractor, how do I tell what it has? Is this transmission good to have or not?
Lamont
02-08-2004 07:21:04
 Re: Re: Re: 801B in reply to Adam, 02-06-2004 20:09:18
I can tell you now that it's a Case-o-matic. All 801s were. The 700 was the same tractor as the 800, but it, (the 700), had the regular standard transmission - no torque converter. I really like the Case-o-matic. However, I've never had trouble with one either.
Lamont
ted
02-06-2004 20:19:59
Well, it is strictly a matter of opinion. Personally, I like them, but most people will pay more for a tractor without it. Case-0matic was a fluid drive, torque converter, that would override the manual clutch system upon starting a load or when encountering hard going. When they work they are very good, but when they go bad the repairs are prohibitive. Case-O-matic will have a clutch pedal that looks like an accelerator on a car. All they do is run a hydralic valve. They will also have a lever on the rigth side of the steering column for engaging the system.
