SC Air Cleaners
Glenn FitzGeral
02-05-2004 14:44:31
I do not have my SC yet. Delivery is set for the end of April. All this talk about SC air cleaners...Are they somewhat of a problem? Why didn't they use the DC type? Are all gasoline SC air cleaner systems designed the same? Thanks, Glenn F.
m. recker
02-07-2004 14:50:19
 Re: SC Air Cleaners in reply to Glenn FitzGerald, 02-05-2004 14:44:31
i have 1953 case sc,ihave no problems with the air cleaner at all! use good maintenance, get and follow owner manual.
D Smoker
02-06-2004 07:24:27
The S series air cleaners were made by United, out of Chicago. One trick I found, if you don't mind striping the paint off the air cleaner, is to get a 5 gal. bucket of carb cleaner and dump the whole air cleaner in it, cleans it better than any other way I've found, you have to repaint the air cleaner then, but if you're doing a restoration, you'd be doing that anyway.
Mike is correct about the other differences in the air cleaners.
Mike Schotte
02-05-2004 17:24:14
Glenn,
Hope you aren't sick of me talking about SC air cleaners... but since you asked, I'll try to answer your questions:
1) I don't think the SC oil bath air cleaners were a problem, unless they weren't properly maintained. If they weren't kept clean, and/or water was allowed to get in there- the oil cup could rust out.
The DC uses that thick cast iron oil cup with removable screen and mesh. You couldn't rust through the bottom of a DC unit in about a million years.
The SC air cleaner isn't really made to be disassembled without a bit of work. The manual tells you NOT to remove the steel wool- just to soak it to remove the dirt and oil from the element.
2) Why didn't they use the DC air cleaner? Don't know- but I would assume because the DC cleaner is a leftover model C air cleaner, and the SC was an "all new" tractor design.
I'd be willing to guess that Case bought the tin air cleaners from a vendor or supplier- but that's just supposition on my part.
3) To my knowledge, all SC air cleaners are essentially the same. The only differences are between the early types and the later types.
The '41 SC had a cleaner where the air outlet was up high- and there was a 'Z' tube that directed the air down to the level of the carburetor intake. The later style had the air outlet on the bottom end- where it lined up directly with the carburetor.
Case SC air cleaner body
Case SC oil baffle
-Schotte
(stepping away from the keyboard)
Klyde
02-05-2004 21:10:09
 Re: Re: SC Air Cleaners in reply to Mike Schotte, 02-05-2004 17:24:14
I think the S series air cleaner was a Donaldson, not positive but seems like I saw decal on one once.
Mike Schotte
02-06-2004 04:56:06
 Re: Re: Re: SC Air Cleaners in reply to Klyde, 02-05-2004 21:10:09
Hi Klyde,
I saw this sticker on a restored '41 SC air cleaner... says it was made by United.
Of course- once you order a new sticker, who knows if it's for the right company anymore?? (grin)
third party image
-Schotte
