case 1370
Doug Franks
02-05-2004 10:19:04
Theres a Case 1370 on ebay, no bids yet at $4000, seems cheap for a 150 hp tractor! What are the pros and cons of this tractor?? Did they have any common problems?? Thanks Doug
Glenn F.
02-05-2004 11:51:45
 Re: case 1370 in reply to Doug Franks, 02-05-2004 10:19:04
That does sound cheap. They were a very good tractor. We have a 1270 which I understand is much the same. It is our favorite tractor as well as any of the neighbors that operate it. The powershift may need a heavy duty upgrade. You might be glad you got the tractor cheap. Glenn F.
Allan C
02-05-2004 20:51:35
 Re: Re: case 1370 in reply to Glenn F., 02-05-2004 11:51:45
That is cheap if it's any good. If over 6000 hrs may need some work. Things to watch for are powershift, coolant in oil, ( usually means leaking around sleeves) The Usual things like how it runs, But I don't know if you can find all this out on ebay!
