Installing Points on VAC
John L.
02-05-2004 08:42:19
What is the correct method for setting points on a VAC (or any other I imagine)? I just finished getting a new set of points and a condensor in. The distributor seems to be at a high point (there appear to be four points that are equally as high, makes sense on a 4 cyl engine right?) and the gap in the points is pretty big - bigger than I could measure with a gauge. Turning the adjusting screw doesn't seem to make a difference in the gap. Correct gap is supposed to be .020, correct?
John L.
02-05-2004 10:44:52
 Re: Installing Points on VAC in reply to John L., 02-05-2004 08:42:19
Well, got the points set. Realized I had tightened the set screw and needed that loose for the adjustment to work. Retightened it when I was done and reassembled everything.
So I'm now getting spark, and it actually fired once. However, that only happened once. Double checked everything - I still have spark (checked at the #1 cyl wire), plugs look good, firing order is correct (at 1342). I'm now back to thinking there may be a carb issue. I dropped the carb from the intake manifold and there is certainly plenty of gas getting to the manifold, so I imagine the engine is getting plenty.
From what I've gathered so far, once the carb was rebuilt and reinstalled the tractor ran for a while. When it was starting to die it would fire up and run for 5-10 seconds and then stall. Sounds like fuel to me.
Anyhow, my father removed the breather stack (whatever it's actually called) and he mentioned that the two studs that hold the breather to the block came out as well and that a lot of antifreeze leaked out from there. This sounds pretty odd to me. Why would those studs fall out like that? Maybe a sign of something else now quite right?
Any ideas on where to go from here? Unfortunately I'm starting to think I won't get this fixed this trip. I have to head home soon since we're do for another storm. Help!
thanks in advance!
Coolant leak not an issue
02-05-2004 12:47:18
 Re: Re: Installing Points on VAC in reply to John L., 02-05-2004 10:44:52
I just checked my vac in the garage, it is down to almost the bare engine block, the studs holding the air cleaner housing to the block are real close to the coolant jacket, maybe 1/4 inch or less. Might just be they are rusted through, as far as the studs comming out DON'T WORRY, Case uses studs with coarse threads on one end and fine threads on the other, the coarse threads almost always break loose first. Just put some pipe sealing compound(pipe dope) on the threads of the studs before reinstalling and check to make sure there are no leaks later.
John L.
02-05-2004 13:40:10
 Re: Re: Re: Installing Points on VAC in reply to Coolant leak not an issue, 02-05-2004 12:47:18
Thank you for taking the time to check that out for me and for elimiating one more possibility!
Chicken
02-05-2004 12:23:35
I will Try to do my best to help;
Yes you are right, point gap is about .020 in(thickness of a match book cover will make it run)
I would also check the quality of gasoline. Is it stale, have water in it etc. Remove the plug at the bottom of the carb bowl and make sure it flows steady eliminating filter trouble or float needle stuck. not sure how you figure by looking at the manifold there is plenty of fuel. I guess you see raw fuel in the manifold. Check the plugs and see if they are wet with fuel or real black to indiciate a real rich mixture or a poor spark problem. Lots of times a small ammount of water in the fuel will cause a start and die sisition. draining the carb bowl is a temp fix, will start and run till it gets full of water again. CHECK FUEL QUALITY, even if you have to put some new gas in a coffee can and drain the carb this can solve a lot of headaches.
Let me know if this helps or if I could help in any othe way GOOD LUCK
John L.
02-05-2004 13:38:44
 Re: Re: Re: Installing Points on VAC in reply to Chicken, 02-05-2004 12:23:35
Thanks a bunch. Draining the tank maybe a good idea. You are correct, I saw raw fuel in the manifold. Plugs look brand new - no carbon (which normally after a few hours they are black in this VAC) and no wetness from fuel either.
I also pulled the carb off and cracked it open while playing around this afternoon. The carb had plenty of gas, floats seemed free and fine, gaskets were new (since the rebuild I mentioned earlier), and nothing really jumped out at me. I reassembled everything and gave it another shot. No fire again.
I'm heading home tonight, so I'm done for this trip. I'll have my father dump the gas that's in it - sounds like he can release that plug at the bottom of the carb and dump what is in there as well without pulling it again - and try some fresh fuel just in case.
The only other thing I can think of is if the timing is out. I tried performing the steps I saw here in another thread about removing the plug from cylinder 1, hand cranking while holding my thumb over the plug hole, and checking the position of the points when I feel outward pressure (indicating TDC). I'm not real sure what I was feeling, but after a couple of times trying this I found times when the points were just opening and times when they were just closing. Not enough to say for sure one way or the other. Call it inexperience. Since nothing there (distributor) moved, the timing shouldn't have changed unless there is a more serious problem I would guess (broken gear?).
Chicken
02-05-2004 17:09:25
 Re: Re: Re: Re: Installing Points on VAC in reply to John L., 02-05-2004 13:38:44
john feel free to e-mail or call on the phone any problems or questions you have, I have a knack of being able to make run anything with any run left to it. Avaible on weekends or evenings
Pete
[email protected]
530-742-2456
John L.
02-05-2004 20:23:51
 Re: Re: Re: Re: Re: Installing Points on VAC in reply to Chicken, 02-05-2004 17:09:25
Thank you! I'll keep your contact info closeby. On my way home I talked with a few other antique tractor enthusiests, one who seemed to know the VAC quite well. Seems like I tried just about everything. The only other suggestions that came out were to see where the rotor was pointing with cyl 1 at TDC to ensure firing order, and to check and make sure the breather wasn't clogged by removing it and turning it over again. My father is going to try the later, and also do a compression test on all cyls to try and rule out stuck valves. I'll keep everyone posted!
ff316
02-05-2004 10:48:18
Make sure the dist cap is not on backwards, I don't know if that is possible or not but if it is the timing will be 180 off and it will not work. Good luck.
Fireman
John L.
02-05-2004 10:54:47
 Re: Re: Re: Installing Points on VAC in reply to ff316, 02-05-2004 10:48:18
Thanks for the tip. The cap actually has a notch that matches a similar notch on the distributor and on the dust cover, so I'm pretty certain that all is right. It sure seems right to me. Looking at how the distributor rotates, I matched the plug wires to the correct cylinders (1-3-4-2) in order from the cap (cylinders I'm counting "one" as the cylinder closest to the radiator and counting back from there). I'm about 95% certain the electrical is working as it should.
ff316
02-05-2004 18:16:03
 Re: Re: Re: Re: Installing Points on VAC in reply to John L., 02-05-2004 10:54:47
That's good, I wasn't sure. Some caps can be put on backwards. If you are not sure if #1 wire is on #1 cylinder terminal you can rotate them around the cap and try to start, repeat until it does. This is what I did on my SC. Good luck.
Fireman
Chicken
02-05-2004 18:51:09
 Re: Re: Re: Re: Re: Installing Points on VAC in reply to ff316, 02-05-2004 18:16:03
My grandaddy told me when I was bout that high #1 on the cap is the clostest to the #1 spark plug.
till this day I always line a terminal on the cap to the #1 plug and make that the first in the firing order. Makes it easy to put the plug wires back on when my horse pulls them off cause I left the tractor in the pasture.
Pete
