David Brown 880 Hydraulic
Eirikur Andress
02-05-2004 07:18:00
Hi,
I have a DB 880 implematic, approx. 40 yesrs old. I have some problems with the hydraulic system. I can not lower the lift on the back of the tractor. I will try to renew the hydraulic oil, (is it the same oil that runs through the gear-box ??). The problem is not depending on the weather, it is also during the summer. I have some idea that perhaps it may be som water in the hydraulic oil, and therefor it do not work. Does anyone have some idea or advises for me ?
Thanks
Eirikur
jpeish
02-08-2004 07:32:54
 Re: David Brown 880 Hydraulic in reply to Eirikur Andresson, 02-05-2004 07:18:00
There is a mechanical latch behind the left lift arm. That will hold arms up.
Other than that ,the arms are controled by the master control valve.
