VAC mixture screw adjustment
art
02-04-2004 20:07:34
How can you determine if the mixture screw is adjusted properly? If not mistaken, too lean and it will damage the valves? too rich and it will burn black? Should I adjust it till it burns black and back it off a quarter turn.. Suggestions appreciated
Carb Adjust Page One
02-04-2004 21:39:53
 Re: VAC mixture screw adjustment in reply to art, 02-04-2004 20:07:34
third party image
Here is the first page from the Case Operator's Manual on carb adjustment.
Carb Adjust Page Two
02-04-2004 21:41:41
 Re: Re: VAC mixture screw adjustment in reply to Carb Adjust Page One, 02-04-2004 21:39:53
third party image
Here is page two
Carb Adjust Page Three
02-04-2004 21:43:27
 Re: Re: Re: VAC mixture screw adjustment in reply to Carb Adjust Page Two, 02-04-2004 21:41:41
third party image
Here is page three. Hope this helps. Pete aka Chicken
F-I-T
02-04-2004 20:21:08
Art:
I';m on the road, so I can't quote the directions directly, but:
I just installed a brand new Zenith carb on my VAC, and the instructions for the load (mixture) screw went something like "with engine warm...adjust in until it stutters, and then out until it begins to smoke as in rich. Then set the screw to the mid point of those two settings. Fine adjust from there."
I did that and it seemed to work well. I put a light load on it and it performed very well.
Hope this helps.
Frank-in-Pasadena
