case 1370 pto
allyn
02-04-2004 13:41:18
pto clutch snap into gear, when it is engaged, which,is hard on pto equipment. is there anything i can do to make the clutch so it engage more smoothly? thank!
turbo
02-04-2004 18:28:17
 Re: case 1370 pto in reply to allyn, 02-04-2004 13:41:18
On later models, a PTO damping tube was used. A 2390 used the A160143 assembly. This is a complete line from PTO valve to PTO housing and costs around $150.00. This will install with no retrofitting.
We used a A161053 assembly. It is used on 4 wheelers and has shorter lines is 1/2 the cost.We retofitted the original line and inserted this unit and it works just as well.
Brent
02-04-2004 21:38:37
 Re: Re: case 1370 pto in reply to turbo, 02-04-2004 18:28:17
Now all we have to do is figure out an easy way to change the gearing to 540 RPM...
