830 trans oil problem
Roger
02-04-2004 13:30:17
On my '62 830, trans oil leaks out from the right shift lever, rubber boot seems snug, is the lever worn enough to let oil by or something else wrong? Thanks
DKase
02-04-2004 19:26:35
 Re: 830 trans oil problem in reply to Roger, 02-04-2004 13:30:17
I had a 830 dual range that finally puked about 10 years ago. It had over 15,000 hours on it and it was shot from end to end! I would have to replace the shift boot on that tractor every 2 years. The other 830's I have had have never had the boot replaced. Go Figure???
Don L
02-04-2004 17:46:44
I bet it is a Case-O-matic. The type A fluid is leaking to the rearend. Look for red oil.If that's the CASE, drain it down, and leave the type A mixture in it or change it. And proceed, a little bypass is fine. Might be water in the rearend too, enough to raise the level to high.
Roger
02-05-2004 19:09:00
 Re: Re: 830 trans oil problem in reply to Don L, 02-04-2004 17:46:44
Don, yes it is Case O Matic. It has TCH throughout the whole rear end, the levels don't change so I don't think oil is moving from one to the other.
