Top Link Question
David811B
02-04-2004 09:14:47
I modified a modern Cat1 toplink to use on my eagle hitch. It is the same measurements now as the original Case toplink, seems a little short, unmodified it was too long. Any one have any comments on this subject?? Share their experiences?-David
Jim M
02-05-2004 17:54:36
 Re: Top Link Question in reply to David811B, 02-04-2004 09:14:47
I made one for a 500b. I shortened up a cat2 link tube. cut the left hand thread rod shorter. Used a piece of the threaded rod on the right hand thread piece with a piece of flat bar welded to the end with a hole in it. I used a piece of pipe with 2 pieces of flat bar to make a hinge to the right hand thread bar. The pipe is used at the tractor end as there is a clearence problem there.
rich
02-04-2004 19:14:20
Have new old stock 800b top links for $135 if interested.
Gene Dotson
02-05-2004 01:45:33
 Re: Re: Top Link Question in reply to rich, 02-04-2004 19:14:20
Gosh, I got a deal on mine. Bought it at auction for $8.00... Gene
Gene Dotson
02-04-2004 14:22:20
David; The original Case top link is offset at each end to prevent interference with the Hydraulic control levers when used at the top position and hitting the cover plate screws when used at the low position. Have to be extra careful when using a straight top link... Gene
