ether starting 580C
JD
02-02-2004 15:39:27
Any advice on ether starts for a 580C. Do I hold the valve open and crank, or open and close the valve to get a squirt in the air intake and then crank?
Kelly MT
02-06-2004 19:53:30
 Re: ether starting 580C in reply to JD, 02-02-2004 15:39:27
It's always best to apply eather when the engine is cranking. As the other fella said, don't use eather with any starting aids like glow plugs or air pre-heaters. Also, just a wiff is all you need.
JD
02-06-2004 21:38:38
 Re: Re: ether starting 580C in reply to Kelly MT, 02-06-2004 19:53:30
Thanks for the comments. No glow plug on mine, just the ether. I will try the suggestions and see if it helps.
JD
Roger
02-06-2004 04:39:46
The 580 C has a glow plug to warm the air when temps are cold. Do NOT use a starting fluid and the glow plug at the same time. Don't know of any valve used during starting on a 580 C. (perhaps an after market starting fluid kit?)Without using the glow plug, give a short squirt of starting fluid into the air cleaner intake. If your motor is good condition, it should start within a few seconds of pushing the start button.
