SC Engine Removal
Rob in Virginia
02-02-2004 09:12:38
I am restoring a 1950 SC and am finally at the point of removing the engine. I would like some advice on the best way attach my engine hoist chains to the engine. Some books show just slipping the chain over the head bolts with a nut and washer. Do I need to be concerned about bending the head bolts? If I replaced the head bolts with shorter bolts is there even enough thread there to support the engine? Would it be better to wrap two chains completely around the engine? Thanks for your help.
Mark
02-02-2004 19:06:52
 Re: SC Engine Removal in reply to Rob in Virginia, 02-02-2004 09:12:38
Why not remove head bolt and temporarily replace with an eyehook that you could slip a small chain thru?
HOOSIER
02-02-2004 18:36:22
Remove head bolt and replace with short one. Tried using head bolt and bent it. Good Luck
