730 Case block heater
len
02-01-2004 20:20:13
I would like to install a block heater in a 730. The dealer has a 600 watt screw in type. I would like something with higher wattage 'cause I use tractor to feed hay about every 3 days. I would like to plug in about 1 hours before firing engine. I was thinking about a 1500 W unit that connects at the top of the water pump and into the tapped hole on the left side of block. Any ideas of size or an easier way? Thanks.
bill
02-02-2004 06:41:35
 Re: 730 Case block heater in reply to len, 02-01-2004 20:20:13
I own a few 730,s and have found using a external 1500 watt heater seems to work best as you only need to plug it in for about a half hour. I tapped mine off the left side of the engine and then put a tee up by the tem. sender. works good. Bill
Gene Dotson
02-02-2004 04:03:45
Len; I think you will be more than satisfied with the screw-in heater. At 600 watts, it will provide as much heat as a 1000 watt tank heater and will be easier to install and no outside mess or leaking hoses. I had one of the screw-in on my 800 diesel and it would start at -10f with about 1 hour heat or it can be left plugged all night as they are thermostat controlled... Gene
