Wheel Weights...Part Number, etc. Needed
Glenn FitzGeral
02-01-2004 14:56:52
I don't have any parts books. Does anyone know the part number for DC/SC front wheel weights? How many different ones were there? Did they make ones for the cast wheels also? I'd like as many part numbers and descriptions as there are if that's not too much to ask. I'm told the parts book is a little confusing on this point. Thanks, Glenn F.
Mike Schotte
02-01-2004 15:39:05
 Re: Wheel Weights...Part Number, etc. Needed in reply to Glenn FitzGerald, 02-01-2004 14:56:52
Glenn,
You guys are working me to death with the parts books this weekend! (grin)
Case "SC" front wheel weights for pneumatic tires:
#5364A weight is shown for both the #04055TS (stamped steel) wheel and the #5741A (cast iron) wheel.
The set of weights (part #1884AA) comes with (8) of the J-hook bolts (part #04780AB) for mounting to the stamped wheel.
The set of weights (part #4440AA)comes with (8) 3/8"X3" hex head cap screws. (I'm afraid I don't understand how in the heck these attach to the cast wheel- there are aren't any holes I'm aware of...)
The "DC" weight numbers are a whole other mess of numbers. I can post them if you really need them...
-Schotte
DKase
02-02-2004 17:31:18
 Re: Re: Wheel Weights...Part Number, etc. Needed in reply to Mike Schotte, 02-01-2004 15:39:05
Hey Mike; The wheels have to be drilled and tapped. I have one set on a 54 DC that is all set up for the weights. I think if you look in the information for the self propelled combine that uses the DC engine you will find where the weights were used with a big header on.
Glenn F.
02-01-2004 18:04:52
Thanks for the info Mike. I talked to a guy today who has one front weight. He thinks it weighs about 35 lbs. He's willing to sell it quite reasonable. He thinks it's for a DC and/or SC. He said he picked it up almost by accident a few years back and hasn't seen another one since. Are these weights that rare? Do you know if there were heavier and lighter ones? This guy is a long time Case guy. I didn't ask him the part number of his. I was under the impression there was only one weight size for DC and SC. Whatever more info you can dig up I'd appreciate. Thanks, Glenn F.
BILL
02-01-2004 15:16:09
Glen I think your on th right track rather than change wheels I have a set of 100 lb weights each side that fit in the cultivator frnt brackets which I think is better that wheel weights to hold front down I could take a picture if it would help but Iam fixing to fly out tomorrow noon could get pict tonight if you want 406 827 2039
