SC Case Toplink Bracket
Glenn FitzGeral
01-31-2004 20:47:01
Does the SC have a toplink bracket which bolts over the PTO shaft the same as the DC? I have zero background with SC's. We're big on the DC's. Thanks, Glenn F.
Bob/wis
02-01-2004 10:26:25
 Re: SC Case Toplink Bracket in reply to Glenn FitzGerald, 01-31-2004 20:47:01
Glenn
I am hopeing by summer to have some of these reproduced. So if anyone is interested email me. I will keep a list of who needs them.
Bob/wis
[email protected]
(608)482-1003
todd hamilton
02-01-2004 05:57:24
Hi Glenn: Only if it is a "new" SC with Eagle Hitch. Most SCs (like mine) have a mechanical lift that is basically 2-point. When Case put the Eagle Hitch on the SC they redesigned the back end of the tractor.
Glenn F.
02-01-2004 07:42:22
 Re: Re: SC Case Toplink Bracket in reply to todd hamilton, 02-01-2004 05:57:24
Yes, I am talking about eagle hitch equipped SC and DC Cases. Do they both use the same top link and bracket? I am not talking about the top bracket which looks about strong enough to tie the seeder/plow trip rope to. Thanks, Glenn F.
todd hamilton
02-01-2004 11:03:11
 Re: Re: Re: SC Case Toplink Bracket in reply to Glenn F., 02-01-2004 07:42:22
Hey - you don't tie the plow trip rope to anything (if you have non-trip boards like we had). When you hit the rock and the spring releases the hitch from the clevis that rope stays with the plow. Dad also taught me not to put it in the middle when you sit on the rope or a nasty burn can occur. We always put ours under the right leg and cheek. Then it is on the "normal" side when you reach back for it. Only 41 but ain't no rookie!:^)
dctom
02-01-2004 08:59:19
YES
martin in De.
02-01-2004 09:55:27
 Re: Re: Re: Re: SC Case Toplink Bracket in reply to dctom, 02-01-2004 08:59:19
Tom,did someone reproduce those brackets a few years back and advertise them in Old Abe's News. martin
