Spindles DC Adj. Wide Front
Glenn GitzGeral
01-31-2004 20:29:56
I've got an adjustable wide front late model DC. It has stamped front wheels. Will the cast iron wheels work on these spindles? I'd like the extra weight for my mounted plow. Thanks, Glenn F.
dctom
02-01-2004 09:04:59
 Re: Spindles DC Adj. Wide Front in reply to Glenn GitzGerald, 01-31-2004 20:29:56
MOST ALL ADJ AXLE'S USED THE SC WHEELES(pressed steel or heavy SC case) BUT LATER ONES 52 AND AFTER WAS DRILLED FOR BOTH SC AND DC WHEELS
bill
02-01-2004 08:24:06
I just switched to adj front had ruint hub on one dc front got another hub (SAME PART NUMBER) off another dc adj front it had different size bearings and fit only after swtching bearings I wonder if the smaller bearing was for an SC spendel but was on a dc. I was not able to fit old cast bearings into the adj hubs as bearing was just too big
