SC transmission noise
Walter Vaughan
01-31-2004 18:09:53
Well I took Todd hamilton's advice and changed my SC tranny oil (it needed it, very black) but it did nothing to help my problem. My sc is making noise (grating and grinding) especially in reverse and 1st gear. 2nd gear gets noisy at high speeds. 3rd and 4th are almost perfect sounding with no noise. Noise is also made ,but not as bad, while in neutral when you engage the belt pulley and clutch. John Salie suggested that it was the input shaft bearing, and he may be right, but if it is, why doesn't it make noise in all gears? Once again I know nothing about transmissions and it looks like I'm fixing to tear this one down so I'm trying to get as much info as possible before I start. It just sounds like the noise is coming from the belt pulley but I could be wrong. I can't detect any play in the belt pulley. Thanks in advance for any replies. Walter
dctom
02-01-2004 09:13:30
 Re: SC transmission noise in reply to Walter Vaughan, 01-31-2004 18:09:53
WALT; IF I REMEMBER YOUR FIRST POST IT WAS THAT YOUR TRACTOR LOST POWER WHEN DRIVEING, RIGHT? WHY NOT BELT IT UP TO SOMETHNG OR FIND A DYNO AND CHECK IT THAT WAY, IF IT STILL LOSES POWER THAN IT IS NOT THE TRANSMISSION BUT AN ENGINE PROBLEM, JUST MY 31/2 CENTS
walter
02-01-2004 20:06:16
 Re: Re: SC transmission noise in reply to dctom, 02-01-2004 09:13:30
Negative , no lost power, I said the noise seemed to get better when you put the tractor under a load. I think Todd may be on to something with the right and left side of the transmission. From reading my manual it seems in order to fix this type of bearing or backlash problem you do not have to split the tractor but only work through the top cover. I think my problem has something to do with the first reduction shaft or its input gear. Does this make sense?
Dave
02-01-2004 03:43:46
Walt,
One thing first, remember its only nuts and bolts shafts and bearings, its not brain surgery, and there are no intricate electronics to navigate.
First off I have worked with speed reducers for 15 years, and in all that time I have seen instances where bearings make a racket, 1. when they are too loose and 2. when they are to tight. What happens is the bearing starts to frete and the bearing surface starts to break down usually in the cup section but I have seen plenty break down in the cone(roller section).
These are all taper roller bearings, so end-float and pre-load are important. If you do go in, there are plenty of people that can talk you through your trouble spots. As long as no gear teeth are broken yet I would suggest not running the tractor any more incase a bearing does self destruct and run itself through the mesh.
Like Todd said Get your self a manual and have at her. Just my thought , but if you do go in do all the bearings and pay attention to the amount of shims on all of the end caps.
Just my long drawn out thoughts
Dave freezin' in Wis
todd hamilton
02-01-2004 05:52:45
 Re: Re: SC transmission noise in reply to Dave, 02-01-2004 03:43:46
Service manual shows two shafts - 1st reduction and 2nd reduction. They are mounted horizontally with bearings at each end. From his symptoms I would think that either the left bearing is bad on the 1st shaft or possibly the reverse idler is loose and moving around. After study in the manual you can see why it impossible to up-shift an old Case tractor while it is moving. Some old IH operators (my extended family is generally Red) like to up-shift from 4th to 5th while coasting down the road. When they drive my Case I tell them not to try that!
walter
02-01-2004 20:13:39
 Re: Re: Re: SC transmission noise in reply to todd hamilton, 02-01-2004 05:52:45
Todd I think you are on to something here. The first reduction shaft is the only thing 1st ,2nd and reverse have in common and that is where my noise is. Can anybody tell me what "backlash" is?
Dave
02-02-2004 07:08:28
 Re: Re: Re: Re: SC transmission noise in reply to walter, 02-01-2004 20:13:39
Walt,
Backlash is the amount of play between two gears in a mesh. It is at the pitch line(center of tooth contact).
in all gear sets you need to have backlash to compensate for growth from heat.
You can do nothing to change the backlash besides taking the gear cluster to a machine shop and having them either shaved or ground on precision equipment.
The distance between the two bores in a housing fixes the backlash depending on the way the final rotating elements are machined.(it all deals with centerlines at this point)((This is a hard thing to explain without drawing a picture)) You will be most concerned with END FLOAT.
That is the distance a shaft moves when the bearings are seated properly against their shoulders on a shaft, and the correct amount of shims are in the covers that hold them in place.
If the shims on your tractor are metal type carefully clean them and reinstall ALL of them(make sure to mark which came from which side), then because you are working from the top cover you will need to get a dial indicator and set it up against the face of a gear, then pry one way and set your zero and then pry the other way, that is your end float number. Add or remove shims to get your desired float.
When a bearing cone(the roller part in a taper bearing) moves in to the cup(the bearing surface) that is where end float comes from.
Long winded I am this morning.
But at least it is warming in Wisconsin
Dave
todd hamilton
01-31-2004 20:04:30
Hi Walter - sorry that didn't work for you. I don't know a lot about transmission either. However, order a service manual for the SC before you tear into it. A picture is worth a thousand words. I am looking at mine now on page 50. The picture there show the clusters for 1st, 2nd, and reverse on the left side of the transmission and 3rd,4th on the right. Looks like 2nd and reverse share same drive gear but one of the old experts will need to take it from here - suggest contacting dctom on this board. He really knows these tractors inside and out. I hope you can fix your problem.
Dr Cy Kosis
01-31-2004 19:03:06
Well there gose another mag to the great salvage yard in the sky..... .....
Hey Walt
01-31-2004 18:58:06
The confusing thing is that you detect no play on the pulley shaft. My experience is that a bad brg. on the input shaft results in play on that pulley shaft. But, in neutral, clutch engaged, the only shafts turning are the input and pulley shaft. The pulley shaft shouldn't be able to rotate fore & aft very much with the engine off. Just the backlash in the gear set.
