Starter motor for Case 580 CK w/188 diesel engine
John Mc
01-31-2004 15:09:18
Does anyone know the Case part number for the starter motor on a Case 580 CK (not sure what year it is). It has a 188 diesel. It has a 4 speed with power shuttle. I've been trying to cross reference with Wilson starters. Anyone know where I can get one? The starter moter works, but the drive gear is shattered. Thanks.
Jim B
02-01-2004 20:32:12
 Re: Starter motor for Case 580 CK w/188 diesel eng in reply to John Mc, 01-31-2004 15:09:18
NAPA has the correct drive unit for your 580CK Diesel for $12-$14. I know this very well because my 580CK has a damaged flywheel ring gear and it eats drive units about as kwik as a few tanks of fuel. Much easier to change than splitting the tractor and replacing the ring gear > but someday it will have to happen. Worries me that usually the broken gear parts end up inside the converter/shuttle case. By the way > either a 9 or a 10 tooth drive unit works OK.
emil selich
01-31-2004 18:10:30
The book shows 2 starters. They are both Delco Remy, 10 tooth pinion has part #a39839, the nine tooth part #a38413
marlowe
01-31-2004 17:44:43
why would you want to go thru all that work just change the starter drive or get the hole thing rebuilt just did my starter for a 188 and was like 75 bucks. any starter and alt. shop can fix you up
Klyde
02-01-2004 06:13:38
 Re: Re: Starter motor for Case 580 CK w/188 diesel in reply to marlowe, 01-31-2004 17:44:43
I agree. Why would you put a rebuilt starter on when all it needs is a drive? I have farmers do that all the time, get some rebuilt POS an stick it on the ir ractor an then a year later it quits an "its only ayear old" so they want me to fix it an nothing inside is what its supposed to be. Corse yours has probly already been (replaced) cause the orignals ALL have numbers from the factory. Thats the first thing they rip off when they "rebuild" them.
