Hydraulic pump on 2390
Shane
01-31-2004 14:31:31
We have found a 2390 that the owner claims has a bad hydraulic pump. How do you change these pumps, I know on the 1070's it is real easy out the rearend and I do know on the 1270's it is up in the belly but don't know how it comes out of the 1270 or the 2390. Do you have to split the tractor or will it come out the bottom of the belly?
ketch
01-31-2004 17:28:16
 Re: Hydraulic pump on 2390 in reply to Shane, 01-31-2004 14:31:31
the main hyd piston pump is located on the left hand side of the trans,just under and back from the cab steps,external replacement only,no split involved
doug@upr
01-31-2004 17:22:54
bad hydr's on a case 90 series, is not always pump related, though if it is the charge pump is located on the bottom towards the front/middle of the tractor, and it just unbolts very easily. the main hydr. pump is located on the left side of the tractor just rearward of the cab steps, it's a little more work to remove but not that hard to access, just a little tighter quarters, and more line to remove.
first though it would take off the compensator valve off of main hydr. piston pump. disassemble clean & reinstall, that may fix the problem. even if the problem persists it could still be the compensator, try switching it with another. usaully my experience says that the main hydr. piston pump usaully is not the problem.
good luck
Shane
01-31-2004 19:06:11
 Re: Re: Hydraulic pump on 2390 in reply to doug@upr, 01-31-2004 17:22:54
Shucks, I forgot to ask if the tractor would move or not. Maybe he just meant the outlets didn't work. I also forgot that the pump in the belly was a charge pump and there was a second one on the side of the tranny! I suppose that is because we never have to work on these old girls! Ha Ha!
