Air Cleaner
JDB
10-02-2006 10:49:23
third party image
third party image
I know, It's not original but I don't think it looks bad on an old work horse.
C. Amick
10-02-2006 10:58:30
 Re: Air Cleaner in reply to JDB, 10-02-2006 10:49:23
Is there a filter in the top? I wonder if you aren't restricting too much air flow?
JDB
10-02-2006 11:22:24
 Re: Air Cleaner in reply to C. Amick, 10-02-2006 10:58:30
Yes, there is a 5 micron air filter with a foam sleeve around it. No, doesn't seem to be restricting air flow. I worked it all afternoon on the bushhog and ran fine. CFM rating of filter is higher than what the engine needs.
C. Amick
10-02-2006 11:31:47
 Re: Air Cleaner in reply to JDB, 10-02-2006 11:22:24
That's good. I'm sure then that it's doing a much better job than just the original oil bath unit.
Walt Davies
10-02-2006 20:01:50
 Re: Air Cleaner in reply to C. Amick, 10-02-2006 11:31:47
Actually the oil bath air filters are better than the new paper type for removing dirt and dust. They went to the paper type because they are easier to clean and change and also they make more moeny with them.
In high dust areas like the dessert they still use the oil bath filters on stationary engine.
Walt
Walt Davies
10-02-2006 20:01:17
Walt
