Case 430 Zenith Carb
Larry Ward
01-30-2004 17:35:39
What is the float setting for the Zenith carb? Mine is pouring gas out the air inlet pipe
JRT
01-30-2004 20:55:11
 Re: Case 430 Zenith Carb in reply to Larry Ward, 01-30-2004 17:35:39
When you adjust the float in one of those carborators, you first set it to what the specs say, then you add approximately another 1/8 inch bend to it just to make sure it is low enough. If you don't they will leak like a sieve.
farmboy
01-30-2004 20:35:24
well i have a case 530 that i got from dad hes had since it was new, then i got it, and mine is doing the same thing.
he tells me that the float is just sticking so i will see when i tear into and it mite just be that only....
and something elese that they are famous far the filter element bowl that sits on top the engine cowl,will leak water and fill your oil bath filter down there in the bottom,with water hince it will get to full and the egine want run in fact it will kill it,it suck the oil up to the to the element bowl and it wont run right at all mine doing the same thing.....
maybe this will help you in the future.....
