sludge in diff/trans
chuckles
01-29-2004 11:56:21
Not sure if I have solved my no power , but have found sludge in my diff/trans case so thick is exactly like roofing tar, same density. Now anyone suggest the best way to clean, gas or diesel or kerosene run through to flush ????
Chicken
01-30-2004 18:39:32
 Re: sludge in diff/trans in reply to chuckles, 01-29-2004 11:56:21
Let it drain, then fill with diesel fuel and let it soak, then drain, if you have it to a point where you can spray break clean in and get to every thing that works best.
Pete
jimmyG
01-29-2004 12:20:18
I have cleaned old crap out with Mineral spirits.fill it up let it sit a while first then drain and flush till clean. at least I have had good luck that way.
