stuck head
pjohnson
01-28-2004 01:47:31
HI. I HAVE A 1955 CASE WITH DUAL HEADS CEN/T GET THE BACK ONE OFF ANY SUGGESTION WILL BE GREATEFUL APPRECIATE THANKS [IN CHRIST PAUL]
CTex
01-30-2004 03:02:36
 Re: stuck head in reply to pjohnson, 01-28-2004 01:47:31
Don't know if you have the head off yet. But if the tractor will roll and the pistons aren't stuck spray down the studs good, put the plugs back in and pull it around for a while in gear. Let the tractor do the job. It will loosen it up and then it should come off without breaking anything.
Pat T
01-28-2004 16:45:41
Had this happen on mine when I pulled the heads a few years ago. Oil & grunge get down along side the studs, heat bakes it all tight. Lots of penetrating oil, be patient. I ended up making a bracket that bolted to the holes where the air cleaner mounts to the block to support a small bottle jack that was used to apply up pressure to the head via the power cell nut. Be real careful if you do this, hate to see you break an expensive or irreplaceable head or block. Don't be suprised if it takes days/weeks for the penetrating oil to soften things up enough to get things moving. Good luck!
Pat
