Case 611 B case o matic
Joseph S
01-27-2004 21:57:25
I have a 1958 caseomatic 611 b. My question is when i pull the starter off i can see oil surrounding the torque converter. Is this normal for caseomatics or do i need to drain this because it has been overfilled. The tractor moves fine when cold or hot. Thanks for any information. Also does anyone know of a good parts source for this model?
Roger
01-31-2004 06:39:42
 Re: Case 611 B case o matic in reply to Joseph S, 01-27-2004 21:57:25
Yes, you will see some oil when the starter is removed. However, it should NOT flow out. If it does, it's overfilled. The Case-o-matic transmission is basically trouble free if you keep the oil clean and the filters changed. While some parts are still available from Case IH dealers, a number of salvage yards have parts.
