Question 4 (final for the day!)
rbf
01-27-2004 11:24:10
third party image
Located in the white circle is a "square plug". What type of fluid goes here? (and what might it be for?) Is this the filler for the torque tube? Does it need filled if this 48 doesn't have hydraulics?
Dave
Chicken
01-27-2004 18:23:11
 Re: Question 4 (final for the day!) in reply to rbf, 01-27-2004 11:24:10
Got to love warm weather action photos, to bad it is still jan.
rbf
01-27-2004 18:03:43
From a city boy who wants-2-be a country boy, thanks for your answers! And until it warms up this is about all the pics I have.
BTW this tractor was given to me in exchange for allowing my cousin to cut firewood off the property.
David
newman
01-27-2004 18:37:39
 Re: Re: Question 4 (final for the day!) in reply to rbf, 01-27-2004 18:03:43
Sure is a nice selections of pictures !!! I am gonna learn to use my camera some day and then learn to get the pictures IN then OUT of this computer and post some. Good Job---- ENJOY
Just get a pet Chicken
01-27-2004 19:09:42
 Re: Re: Re: Question 4 (final for the day!) in reply to newman, 01-27-2004 18:37:39
You can teach them any thing, such a small brain there is not much up there to confuse them
Pete
Ugly Chicken
01-27-2004 16:38:01
Just one note, there is a seal between the torque and trans that tends to leak unless some one replaced it. the torque tube oil level is several inches higher than the trans so torque tube oil leaks into the trans and rearend, causing it to be overfull and it will leak out of the trans vent. not a big deal unless you spend the money to replace the trans oil and the torque tube oil crosses over and re contaniminiates it.I think I miss speled that. Pete
Glenn FitzGerald
01-27-2004 14:46:19
Hey, you can ask all the questions you want as long as you keep posting pictures of sweet little tractors like that! Glenn F.
Joe (Wa)
01-27-2004 13:53:08
SAE 90 gear oil for tractors without the LP hydraulic system. 8 qts or to level of the fill plug. To lubricate drive shaft bearing and belt pulley gears.
