3 questions
rbf
01-27-2004 08:36:57
third party image
Question 1. How do I drain the trans oil from a 1948 VAC
Question 2. Should it (the oil) have the same color as pancake batter?
Questin 3. The square openings on the sides of the 48 VAC (just above the front wheels) what are they used for?
Thanks
Dave
rbf
01-27-2004 17:54:35
 Re: 3 questions in reply to rbf, 01-27-2004 08:36:57
Thanks to everyone that helped with questions 1-4. Also I do have the operators manual, but since it is from 1948 and I wasn't around then, some of the lingo is hard for me to understand :} I would rather get it from oldtimers that were -- (ouch! ;} )
Once again thanks for your help!
Bob
01-27-2004 16:06:45
1. You drain the trans fluid under the bottom of the transmission. 2. The color is because you have water in the oil. 3. The square holes are for mounting implements such as cultivators. If I be of any help, you are welcome to email me. Good Luck , Bob
Joe (Wa)
01-27-2004 10:41:03
1. Drain plug is on the bottom. Original plug has a recessed square drive. You just about have to crawl under to spot it the first time.
2. Pancake color is emulsion (water).
3. Square hole in front support is for implement attachment.
dctom
01-27-2004 09:11:32
ASK TODD H HE CAN EXPLAIN IT RIGHT (GRIN TODD)
todd hamilton
01-27-2004 12:49:30
 Re: Re: 3 questions in reply to dctom, 01-27-2004 09:11:32
I find operator and service manuals to be right handy!:^)
teachin chicken to raed
01-27-2004 18:35:18
 Re: Re: Re: 3 questions in reply to todd hamilton, 01-27-2004 12:49:30
not quite got it down yet but when he does I'll get some of them there munuals
Pete
