400 case dual head.
paul johnson
01-27-2004 07:27:19
I HAVE A 1955 CASE DUAL HEADS THAT I.M TRYING TO GET OFF PLEASE/ IF YOU KNOW ANT WAY IT WI.LL BE GREATELY APPRECIATE THANKS PAUL.
Roger
01-27-2004 18:28:55
 Re: 400 case dual head. in reply to paul johnson, 01-27-2004 07:27:19
Paul,
With everything loose and bolts out, those heads can really be stuck. Get a 4 to 6 foot pipe that fits into the intake port of the head without much slop. Insert the pipe into the intake port and lift the pipe. The head pops off. Works everytime for me and never causes a problem. Good luck.
caseman-d
01-27-2004 18:03:51
you have to unbolt the watermanifold, exhaust and intake manifold, remove valve covers and rocker arm assembley and unbolt the head, if your pulling the front head then you may have to remove more parts of the front of the head.If diesel then you need to unhook injector lines.
caseman-d
when putting back together don't tighten the head bolts till manifolds been tightened
