Block Heater help needed
Ricky P
01-27-2004 06:38:28
I need to install a block heater for my 970 case so it will start when it is cold. Where do I get these from and where do you install them at?Thanks, Ricky
DKase
01-28-2004 09:55:45
 Re: Block Heater help needed in reply to Ricky P, 01-27-2004 06:38:28
There is a frost plug hole above the starter. Your Case dealer will have a heater that fits in there. They work much better than an external heater and take less juice. They work to -23 degrees. (This mornings experience)
Klyde
01-27-2004 16:09:55
Left side of engine block there is a pipe plug between the cylinders. Thats where the CASE screw in ones go. Ought to still be able to get them from CASE. 6 cylinder may even have room for 2.
Gerald Michaels
01-27-2004 15:46:02
Hello, Auto Zone has them for rad. hose. Have a good one
old
01-27-2004 11:10:54
There are many types of block heaters from magnet types to freeze plug types and even ones that go it the rad. hoses check value bilt drop the E and add .com
