adjusting clutch on 730 CK
Rusty Godwin
01-26-2004 20:31:28
Can anyone tell me how to adjust the clutch on this 730. The tractor will not hardly move when put in a high gear unless it is at idle and then gradually increase throttle. Seems as if the clutch is slipping. Also the PTO will turn a mower, but as soon as the mower hits the grass it stops turning completely. Will adjusting the clutch work or do I need a new clutch. Thanks in advance for your advice.
ubtractorguy
01-28-2004 02:30:04
 Re: adjusting clutch on 730 CK in reply to Rusty Godwin, 01-26-2004 20:31:28
Pedal free play is the only adjustment for i know of for the clutch.Free pedal movement should be 1.75-2.00 inches
JRT
01-26-2004 20:50:23
Rusty, I am not sure, but I don't believe there is any way to adjust the clutch on your 730. Mine did that and I just installed a new clutch. It was not as big a job as I thought it would be. The P T O problem has nothing to do with the clutch and it is probably an easy fix since it does have an adjustment. There is a Cap you can remove on the side of the p t o housing and take a special tool and reach inside and tighten up the pto clutches. If it takes very little pressure on the lever when you put the p t o in gear, then you need to adjust it.
