Synthetic or Regular Oil for DB 990 diesel
Ritchie Leslie
01-26-2004 12:29:42
I have a DB990 diesel tractor. About 30-35 yrs old. Only run it about 80 hrs a year. Runs great.
Weather has been really cold here for a month. Even after a few hours on a block heater - starts OK - but oil pressure takes a few seconds to come up. I'm worried about wear until the oil starts flowing.
Seems like synthetic oil would offer me increased protection and last for years with my usage. Comments, anyone?
Randy
02-03-2004 15:20:32
 Re: Synthetic or Regular Oil for DB 990 diesel in reply to Ritchie Leslie, 01-26-2004 12:29:42
Use Chevron Delo Diesel oil; 30-weight in summer; multiweight in winter if it bothers you. Diesel oil is formulated a little differently to deal with the acidity caused by the small amount of sulphur in Diesel fuel. We used single weight in ours for years, no problems. I even put it in an old Buick I have which sits up a lot, due to the acid-fighting properties.
One problem with synthetics: if the engine is old, it tends to leak much more, and engines with considerable wear will use more. It's great for engines which run hot, like towing, motorhomes, etc., as heat doesn't break it down as quickly.
wolverine
01-26-2004 21:07:23
RL, In very cold conditions a sythetic based fluid will flow better, but with the block heater plugged in, I would not worry about a momentary delay in oil pressure. Also an oil of synthetic base would not be able to go years on a machine used so little. the tractor is still going to go through the same condensation and contamination. also one of the weaknesses of a synthetic base fluid is its rust inhibition during storage, and at 80 hours per year this machine is sitting a lot. Your best bet is a high quality mineral base fluid, especially a Pure Parafin base mineral oil. Synthetic fluids are a wonderfull thing and have many great places to use them, but heavy duty mobile equipment is not the place, either in engines oil, Hydraulic systems. Synthetics are best used in factory and industrial equipment where regular oil analisys of the fluid can be done to monitor fluid additive levels and contamination levels. This is more suitable in these enviroments do to the availability of sample ports on the equipment that make sampleing and analysis of fluids more accessable.
