case SC\ VAC
socal
01-26-2004 09:37:25
just purchased #4912227SC and also a vac parts tractor with a cracked block , where can you check oil level on SC? no place for dipstick or sight level!! perhaps a part changed in its long life on the farm?
dctom
01-26-2004 11:23:01
 Re: case SC\ VAC in reply to socal, 01-26-2004 09:37:25
TWO PLUGS ON SIDE OF PAN, TOP ONE FULL LOWER ONE ADD, ONE IN BOTTOM IS TO DRAIN
todd hamilton
01-26-2004 12:11:29
 Re: Re: case SC\ VAC in reply to dctom, 01-26-2004 11:23:01
I always wondered what that big plug on the bottom of the pan was for????:^)
You Dummy
01-26-2004 15:47:47
 Re: Re: Re: case SC\ VAC in reply to todd hamilton, 01-26-2004 12:11:29
That big plug is for adding oil.
Ima Dummy
01-26-2004 16:26:59
 Re: Re: Re: Re: case SC\ VAC in reply to You Dummy, 01-26-2004 15:47:47
Sumbody told me that the little top hole was fer puttin' oil in - when you couldn't get no more in she was full. Takes quite a while if she's more than just a little low - 'specially if its cold outside. Glad to hear I can use the big one!
tomturkey
01-27-2004 09:02:12
 Re: Re: Re: Re: Re: case SC\ VAC in reply to Ima Dummy, 01-26-2004 16:26:59
I believe that reverse went out of my VAC this morning while plowing snow. You mentioned a VAC parts tractor. I haven't had time to fully diagnose the problem, but am looking for solutions
grant
02-02-2004 22:47:16
 Re: Re: Re: Re: Re: Re: case SC\ VAC in reply to tomturkey, 01-27-2004 09:02:12
what do you need, Im a bit out west,
tomturkey
02-03-2004 05:26:54
 Re: Re: Re: Re: Re: Re: Re: case SC\ VAC in reply to grant, 02-02-2004 22:47:16
I'm not a gear head, just stumble along with nut and bolts. But it appears that the gear that runs reverse is very worn on the front smaller gear. The bearing or spacer on the shaft that it glides forward and back is shot. It also appears that this shaft is well worn. At this point I need to get a shop manuel so I can correctly name these various parts and the procedure for R and R.
grant
02-08-2004 02:37:52
 Re: Re: Re: Re: Re: Re: Re: Re: case SC\ VAC in reply to tomturkey, 02-03-2004 05:26:54
find out the names of parts that you need and let me know, i probably have them, what state are you in?
dctom
01-26-2004 16:17:59
COME ON TODD, ANY ONE THAT CAN SEE PLUGS IN THE SIDE OF THE PAN AND STILL LOOK FOR A DIPSTICK IS A REAL DIP STICK, HAVE TO EXPLAIN EVERY THING TO HIM LOL
todd hamilton
01-26-2004 17:26:51
 Re: Re: Re: Re: Re: case SC\ VAC in reply to dctom, 01-26-2004 16:17:59
Maybe he thought the oil level should ride higher than the top hole. Probably one of those 6 to 12 jumpers we had last week!:^)
so cal
02-01-2004 22:44:45
 Re: Re: Re: Re: Re: Re: case SC\ VAC in reply to todd hamilton, 01-26-2004 17:26:51
yeehaw yuk yuk,thanks for the info you redneck bastards!!!hey look over there, the barn is on fire!!!!
ff316
01-26-2004 10:16:32
If I remember correctly there are two petcocks on the right side of the tractor on the oil pan. If you open the bottom one oil should come out. I'm not sure but I think the upper petcock was there so tractors burning kerosene or distillate could drain off any that ran into the crankcase.
Good luck, Fireman
